For SBC,.. whats the difference?
I recently bought a Carter M6900 so i can have a steady 6psi of fuel pressure w/o the use of a regulator.
The original pump that was on my ZZ4 engine and the delphi unit i replaced it with, have the same pump arm shape versus the carter unit i just bought.
Using the edelbrock fuel pumps as an example of what im talking about, 1st pic, my carter m6900, the 2st pic(#1721) and the 3nd pic(#1722), according to edelbrock, the 1721 is for SBC and the 1722 is for BBC, the carter has the 1721 arm and the delphi and the pump prior to that has the 1722 arm.
Why im asking is because, with the engine set to cylinder #1/TDC, the cam eccentric for the mech fuel pump should be on its heel, when i installed the delphi pump some time ago, i remember the pump arm was pushing against the pump rod slightly and i had to put some pressure on the pump itself just to get the bolts lined up on the block to bolt them down, now when i put the carter m6900 pump on, it bolted right in with just about zero resistance, so i dont know if the pump push rod is even touching the cam eccentric. and that bothers me, but i see the reason why now, the pump arms are different. I put the carter pump in earlier today while also revamping the pump to carb fuel line and filter route, but i havent started the engine yet because of this conundrum.
Can anyone shed any light on this, is there really SBC and BBC pump arm only differences?
Thanks
EDIT - This is one fine example why i'd rather convert to an EFI gas tank, route supply, return and vent lines along with a FP regulator and do away with the whole mechanical fuel pump debacle till i can totally commit to EFI.
Thanks
