Miracle Relays/circuit breakers?
UC645
1,081
3,064
Kittanning, Pa
I figured I’d ask here since I’ve had no luck finding anything.
I’m looking for some sort of switch/relay/circuit breaker that once current flows through it, it stays on and kicks off once it senses more than a certain amount of resistance, even if you’re not using a constant on style of switch. The best example I can give is the 99-02 Chevy truck’s had that function built into the driver’s side window switch.
Anyone ever hear of such a thing?
81cutlass
4,648
13,561
Western MN
G body power seats used a circuit breaker fuse. Actually pretty much all older GM stuff used circuit breaker fuses. They come in 30 amps mostly but you can get aftermarket ones in all amp ratings.
I actually use one for my electric fan. When the fan turns on it spikes current draw and it always blows the normal fuse. The circuit breakers seem a bit more resilient to short high amp draws and I've had good luck with them.
UC645
1,081
3,064
Kittanning, Pa
Depends on the application, but it sounds like you're looking for a current limited switch.
I think those are what I’m looking for, I just have to dig through the catalogs. If all else fails I’ll use limiter switches to cut power to the relays.
Did pontiacgp delete his post? Either way, I think those circuit breakers will come in handy for something else I’m planning on using, thanks for that link
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I deleted it cause I saw that those I listed were not what you are looking for but if you think they will come in handy for another project here is the link
