442 Missing something??
08Malibu
1,447
3,386
North Jersey
Mine is off because a PO of the trans ground the mounting holes off to fit headers on the car I pulled the trans from.
1,167
2,638
West Virginia
I have never run one. I've also never had an issue with stones, rocks, or anything bent. Then again I never treated my car like I starred on the Dukes of Hazzard.
I think the right answer in this case is if you don't know what it is, but you are concerned that it is missing, then it will probably worry you enough that buying a new one wouldn't be bad idea. I'd send one your way for free if I hadn't pitched them all in the scrap. They're cheap enough new.
Jims442
149
66
Connecticut
Ty I appreciate that No it doesn't bother me and the car is never in the rain. So I think it will be fine.
20,391
Actually Checked that out yesterday . transmission pan gasket leaking only. Will put that on my to do list next Ty
it looks to be more then the transmission pan leaking... :unsure:
2650cbc0-9798-4bbe-aeee-59b1f7941c80-jpeg.149914
500/600
1,167
2,638
West Virginia
Nah. It ain’t that bad. Drive it and fix it this winter.
Jims442
149
66
Connecticut
Right now I'm fixing some rust on the lower part of the doors and repainting the grey. I will clean everything up underneath and check for l
other leaks when done. Ty for pointing that out I do appreciate it. The top side above the oil pan is clean and the block is clean as well. When the car sat over the winter I did notice one quarter size spot on the floor under the transmission pan but nothing anywhere else. The oil on the oil pan is old I think it just needs some good cleaning.
LeftLaneOnly
293
486
If you work on the under side of car and it’s running that will be moving 👀👀
Be careful not to put hands or tools near that Saw blade
