Now that I understand,
No. Nobody makes brackets to mount LS compressors to SBC's that I am aware of. The LS compressors are FAR much less universal than previous styles. The R4 compressor and Sanden styles have universal/standard brackets so a R4 compressor from an olds would fit on a Buick V6 and on a SBC. But, LS stuff is kinda application specific and a F body AC compressor is different than a V8 Trailblazer and it's different than a Tahoe which is again different than a V6 4.3 sierra.
There is really no benefit to running a LS style compressor on a SBC. You can make an R12 comp run on R134 so no issues.
If you want to use a compressor that is forward/backwards compatible you can do one of two things.
1. Get your stock SBC R4 style compressor converted to R134a working and when you do LS swap buy a Holley, dirty Dingo or any of the many R4 to LS compressor bracket kits
Now available from Holley are complete A/C kits that have everything needed for the application. Already have the P/S pump and alternator system from the donor truck or car engine? These complete A/C brackets kits move the compressor up high and away from the frame rail (no more notching!)...
www.holley.com
2. Buy a Sanden compressor adapter kit for the SBC and then buy another adapter bracket kit for the LS.
Small Block Chevy Long Water Pump Accessory Steel Mounting Brackets
www.alangrovecomponents.com
348 - 409 Chevy Mounting Brackets
I have no preference for Holley, Dingo, or Alan Grove stuff, never used any of their products, and there are a ton of other options available.
Personally I like the Sanden compressor option if you don't have an existing set of AC hoses or an existing R4 compressor.
