Monte Carlo Radiator Hose Sizes
eric_cspan
22
29
13
Most aftermarket G-body radiators available have 1.5" or 1.75" inlet/outlets.
Is it correct that Montes have 1.25" inlet and 1.5" outlet?
Are the cores and everything the same?
We are looking to make a direct fit for your Monte Carlo owners :)
pagrunt
9,127
15,257
Elderton, Pa
It should be 1.5" upper/1.75" lower. Will it fit the rad support better than the current one you guys have? Cause I'm not liking the fit issues I brought up after I got it in the fall. Still seems like the tanks will rub the top after I get a shroud trimmed where it hits the cooling fins, looks like it's close to .25"-.40" wider too.
eric_cspan
22
29
13
We can make adjustments on that too.
What year and model do you have it in?
eric_cspan
22
29
13
Do you have any pictures. It's hard going by just text.
Also, have your tried factory style pads instead of the prothane?
pagrunt
9,127
15,257
Elderton, Pa
I'll have to see what file I put the pics in. I went with the Prothane ones cause I didn't want to cut up any originals as the are not open enough the fit your tank ends/cooling fins cross bar. Over all the '78-'88 A/G body radiator seems to be a slight scale bigger than what would be a true direct fit. FYI my fitting of the rad is being done with the rad support out of the car as I'm working to get the support mounted on the frame to have my rebuilt 350 broke in before the body goes back on.
eric_cspan
22
29
13
Gotcha. Yea see what you can come up with pictures. Either post here or PM me what you have.
200kss
20
Missouri
The upper port on a stock gbody monte radiator is in fact 1.25 inches. I'm going through this now with a Cold Case radiator, trying to find an upper radiator hose that fits. The original GM hose and new stock replacements are too small at the radiator size. Does anyone of a stock style molded type upper hose that has 1.5 ends on both sides?
