So for my project 86' Regal with it's current good running 307 Olds I was looking at putting a factory dual exhaust set up on it from the cat back and was looking at Autozone and both of these cars even though their exhaust systems look very similar the Monte appears to have 2" mufflers with offset/offset and the 442 has 2.25 muffler's that are center/center.
The two tailpipes and intermediate pipe are cheaper for the 442 and I imagine it would be a direct fit for my Regal with a 307 but the problem is there is basically only one oval muffler that fits this application while the Monte would have many options because of the offset/offset design.
Eventually I will be building a 383 for the Regal and at that time I will install headers and true duals but for the time being I would like to get rid of the stock single exhaust with the muffler behind the rear end.
So I am wondering if there would be much of a difference in fitment between the two systems, if there really is a size differance and if the catalytic flange is the same, I will also be modifying the tailpipes to exit like a GN.
Here are the two replacement mufflers: http://www.summitracing.com/compare
