More power
Quilly Cochran
11
How can I get more power out of my 355 sbc I have a 750 Holley double pump carb the stall is like 19-2100..I recently bought a bigger fuel pump Holley and a MSD-85551 Distributor, Pro-Billet, Magnetic to match the msd box I got I’m looking to put it on this weekend..I need answers !!!
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
first thing is to get a smaller carb, a 500 cfm Holley will work great on that engine
pagrunt
9,159
15,328
Elderton, Pa
images
But seriously what cam are you running? Might be able bump up on that but it may not be a quick addition. I agree with pontiacgp on the carb.
Quilly Cochran
11
  • 310 hp @ 5400 rpm
  • 360 ft.-lbs. @ 3900 rpm
  • 4-bolt main, 1-piece rear main seal
  • Passenger side dipstick
  • Align honed main bearing bore
  • Cylinders honed on computer controlled machine to within .0002 straightness and roundness
  • Cylinders are sonic tested for thickness
  • BluePrint premium cast iron crankshaft
  • Hypereutectic pistons
  • Chevy heavy beam rods with 150,000 PSI bolts
  • Aluminum dual plane intake
  • Harmonic balancer
  • Hydraulic flat tappet cam
  • .480 intake / .486 exhaust & 229 intake / 230 exhaust duration @.050
  • Heavy duty double roller timing set
  • BluePrint premium center bolt cast iron
  • Hardened retainers and springs
  • 2.02 swirl polished intake valves
  • 1.60 swirl polished exhaust valves
  • 9.5 to 1 compression
  • New valve covers, oil pan and timing cover
  • Brass freeze plugs
  • 153 tooth flexplate w/ single 3-bolt converter pattern 10-3/4" bolt circle
  • New HEI distributor
Notes
Zinc Additive Required For Flat Tappet Application,
lilbowtie
3,460
3,965
Canton Mi
More camshaft - What's your expectations?? Your cam, heads, intake, carb, convertor, and gear all have to complement each other. With 310 HP you have the power to get into the 12's
Quilly Cochran
11
I’m only doing the street I wanna get to at least 375-400 hp
