What pressure do you run? I had mine down to 19, and it was all over the place. 21 seemed to spin easy. Did I not heat them up enough?Nice them Nitto tires last forever have two years on mine and I drive the car to the track it also helps that I’m only 7 miles from the track
Not very consistent if you plan on using them for dragracing
Best bang for the buck
I found a work best at 15 psiWhat pressure do you run? I had mine down to 19, and it was all over the place. 21 seemed to spin easy. Did I not heat them up enough?
Stick with the Nittos your back or knees couldn’t handle that car if it got real traction ha haBut, but, but the Nittos were CHEEEEAP! 🤪
