MSD Starter
Tuffregal83
639
1,150
Lockport, Il
So I broke down and bought a MSD mini starter for the Olds 350.
Since I have one on my BBC and love the way it fits and cranks over that engine.
So I got it and bolted it up well wtf hits the oil pan/ block where the oil dip stick goes so I put a email in to see what they have to say.
I already trimed the oil pan lip off still not enough room
Rktpwrd
Builder of Cool Shjt
4,167
23,917
Calgary, Alberta, Canada
Powermaster clockable for the win.
Reactions: 6 users
Tuffregal83
639
1,150
Lockport, Il
So 3 weeks ago I sent pictures to
Holleyperformance there ebay name.
After waiting for 2 weeks on a answer because they had to send the pictures to their engineering department to figure out why the starter wasn't fitting. Well I had enough told him to sent me a return label and they said I can return it well I hope so since it doesn't fit. To top it off their engineer department has no answers.
  • Sad
8,823
7,775
Melville,Saskatchewan
I also had no idea this existed either. I am using a Ebay special on my Olds 350, similar to the smallest Powermaster mini starter. I actually had to grind on the body of the starter to get it fit tight to the block, it hit in a similar spot.
  • Informative
Tuffregal83
639
1,150
Lockport, Il
Well don't waste your time buying one cause there is no way for it to fit
8,823
7,775
An FYI, the sbc mini starters do fit the Olds V8.
  • Informative
xylorex
305
395
New Orleans, LA
I had a similar problem on my Monte Carlo engine build, the issue was the aluminum mounting block was for the wrong tooth/diameter flywheel...
Took me a little while to figure it out haha
