Hello Gbody fans. I’m pretty new to this sight but thought now is a good time as any to start a build thread on my recently purchased 78’ Pontiac GP/SJ. I’m sitting up in a crane at work and the roll mill is down, I get pretty board.
From what I can tell it’s been here in Minnesota since around 2009 and is a original Idaho car. The previous owner passed away and was sold by one of his sons.
The car is rust free and came with a 1979’ 454 truck motor installed. The internals are stock and has a bunch of new aftermarket parts under the hood.
Holley strip dominator high rise intake.
Edelbrock 750 carburetor.
Billet distributor.
Aluminum four core radiator. 170* thermostat.
Dual electric fan set up.
Chrome 150 alternator.
Polished aluminum water pump.
Summit electric fuel pump.
Oversized front coil springs.
Oversized front sway bar.
New rear coil springs
Dual Flow masters.
That’s about it that the car came with. I have since had to strip the underside of roof from surface rust and coat with POR-15 rust preventive coating. I also put a sound barrier on to of that.
I have a headliner coming any day now from stock Interiors.
I also wanted to tint the back and side quarter windows. My back window had the defrost lines in glass but found a old Gbody cutlass at you pull our parts in Rosemount, Minnesota that had good Clear back glass I got for $22.
My car was a landau roof car but luckily the previous owner had both back quarter Window interior panels from a non-landau car sitting in the trunk. I don’t plan on putting a landau roof back on it.
When I got the car I noticed it had two small patches of surface rust inside trunk on both sides just behind the inner wheel well.
I have since sandblasted both spots and coated with POR-15. Real happy it was only surface rust and didn’t eat metal!
Another nice thing about this car, it has all its trim except the side panel trim which I wouldn’t put back on anyway.
This car has a 700R4 that I plan on changing to a 4L60E or 4L80E. The car has a 10 bolt 411 in rear that will need to be a 12 bolt. I also plan on aluminum heads and bigger cam in the 454. It’s not near where it needs to be at the moment! Any suggestions are more than welcome!
These first pics are from the day I picked the car up in a snow bank I had to shovel myself before the flatbed driver showed up. The car sat all winter and fired right up.
Billet distributor.
Dual Flow masters.
