My 83 Monte Carlo SS carb LS build
6spdg37s
369
259
About a month ago I got a tip from a friend someone was selling a clean Monte Carlo SS in blue with a locked up 305.
I go check it out and turns out the car is clean, minimal rust, was someone's show car at some point, but sat outside for about a year.
Make an offer, offer accepted, go with the tow truck and pick it up.
I spent the next 3 weeks recovering from eye surgery and playing with different ideas for the motor and the car. I was really leaning towards a 383 stroker and then my boy pressured me to try to find a LS motor.
picked up a LM7 5.3 with 100k on it and started to disassemble it and clean it up :
no sludge, no dex-cool gunk build up, spins freely, no metal shavings etc; overall I think I got a great 5.3
all the parts are ordered so I am just waiting for stuff to get done/ delivered then i can start putting the motor together.
-CTS-v Oil pan kit
-comp cam 232/234 .595 /.598 110LSA
-243 heads ported, valves , and milled down to increase compression with BTR .660 dual valve springs shimmed
-ls2 timing chain
-ls6 oil pump
-holley 670 CFM carb
-holley carb intake manifold
-ls7 lifters
-tci flex plate
-truck accessory drive (no A/C)
-msd LS box
-champion 3 row radiator
-fan shroud (need to see if my ls1 fans from my camaro SS will fit it)
-texas speed f-body 1-7/8 long tube headers
im sure theres more I don't remember I will add later
very excited to be doing this build
Reactions: 5 users
Texas82GP
Just-a-worm
Apr 3, 2015
7,987
18,693
Spring, Texas
Glad to see you started a build thread. I'll enjoy following along with your progress.
6spdg37s
369
259
ill be sure to include the pictures of me ripping my hair out when I run into problems ! ran into alota issues with my 01 camaro SS build but the fact that the car is done now and all set the feeling is amazing !
awdblazer
314
81
i would like to know what motor mounts you are going to use and which msd box your going to use
thanks
6spdg37s
369
259
thanks
whats up bro ! I ordered the carshop inc 1" LS setback plates, my understanding of this is those mount to your motor, then you take the SBC clamshell mounts and mount them to that and then to the car obviously.
the msd box is MSD # 6012
awdblazer
314
81
excellent i would like to see how they fit
i want to run ac in my build
have you looked into the new msd box? 60143 i believe?
6spdg37s
369
259
the only difference i am seeing is this " Can be installed on both 24x and 58x crank trigger engines"
I have a 24x crank trigger so that's the box that I ordered.
Hickrocket1258
105
24
West Chester, PA
Did you ever think about looking at the Daytona Sensor Smart Spark. It's called something along those lines. A little more pricey but hear nothing but good things about it.
6spdg37s
369
259
I seen that but it seems like it's just slightly more adjustable so I'm ok with the Ls msd box for now
