My aching 60’ foot
1320John$$$
951
2,043
Pennsylvania
Slower car is out 60 footing the faster car and my consistency is a poor showing
Has anyone ever experiment with the vacuum advance in the distributor to improve 60 foot or help in the consistency of
Things I have tried
Leaving at a higher or lower RPM
Taller rear tires
Change right rear shock .01 Decrease in ET zero help in consistency
Reinstalled front sway bar no change
Add weight to car no change slower ET
Solid motor mount or engine limiter is the next thing I’m going to try
Throw any suggestions out that you have worked thanks
Soon to be called first round John
Kemper1976
172
463
Topeka, KS
What’s your current setup? Current 60’ & 330’ times, ET, Weight, gears, converter, transmission, slicks, radials etc.....?
Kemper1976
172
463
Topeka, KS
Kemper1976
172
463
Topeka, KS
I’m taking about both of my cars The slower car out 60 foots the faster car
Okay I see what you mean now. What’s the setup in the faster car.
Kemper1976
172
463
Topeka, KS
Stock 87SS 383 th350 4:10 GN rear 275/70/15 nitto
What tire pressure do you run in the Nitto’s? Are you spinning when you launch? The Nitto’s work okay but not near as good as the Mickey Thompson drag radials.
1320John$$$
951
2,043
Pennsylvania
I ran Mickey Thompson R and Hoosier drag slicks Nothing changed I tried baking them in the burn out box and I also tried shorter burnouts along with tire pressures
