Go back to the hood. It appears to me from your picture that you have a center trim hold-down peg hole that will be left open directly under the hood scoop. NOW is the time to go fill that in. You will have to unless you can make darn sure you 100% seal up your hood scoop. Otherwise, you will get water in there and it will find its way through that hole. H/O hoods did not have that hole pierced.
Since NO W40 hood was aluminum, then all aluminum hoods aren't set up for the hood scoop.
