Spent a little time yesterday to start to install my custom Dakota Digital gauges. I have the BIM-01-2 module which plugs into the ALDL connector of LS engines & will get inputs for the speed, tach, temp, oil pressure, & check engine light all from one wire.
Removed all existing electrical contacts, lights & the flex circuit board. The extra cut on the left was not needed for these, I had done that for a electronic speedo I made in the past. But the otherr brown areas are needed to remove some ribs for clearance.
Mounted in the dash, fresh coat of flat black paint on the trim
