Yeah, the 4L60E is junk especially towing and the aluminum front diff is weak, no posi or locker available. Still my 94 Z71 would push snow over the front bumper with just a Gov bomb in the 8.6 rear. I have a 2000 Dodge Dakota. I did the 3.9 to 5.9 swap. I went through the injector wiring three times and tried two different computers, still no #7 and #8 injector firing. So I piggy backed off the two injectors in the firing order, works sort of OK. Shakes in gear in reverse and bucks at low speeds. I had a head crack badly so I put on the Ram EQ heads. I should have glued the head gaskets in place, moved around, damaged a bit when putting iron heads on in the truck. Now a head gasket is leaking a few years later. Also no locker for the Dodge 205mm front diff, decently strong and even in 1/2 tons but no locker or posi, open is the only option. It has a 8.25" with a Track Lock. It is to heavy to float on top of snow and not heavy enough to dig down in the snow. When I do the head gaskets I am going to probe the harness to see if I somehow put the injector wires in the wrong spot. With the better first gear in the 42RE and 3.91 gears, this truck should haul *ss, like low 15's, not terrible as is , just not as good as it should be for power.
That Ford makes less torque than an LS.
It's a 5.0L, it makes less torque than a Corolla starter motor
I saw a 95 1500 for sale with the heavy duty axle swap. If they would have done the 4L80E swap, I would probably own it. Yeah, the stock 5.3 LS, pre Gen 5 motors stock are gutless turds down low, just pathetic.I have the big front diff to swap into my 1500. That'll be the end of the weak shjt for that truck. It has the 9.5" rear too along with hydroboost. The vacuum brakes sucked *ss.
Friend had one with an oddball 5 speed with a short 5th. That truck worked pretty well.
The 5.0L is a dog. I've discussed it in this thread before. Ford guys know it too. Everyone wants the 5.8L or the 7.5L. Even the 4.9L has more usable torque than the 5.0L. I discussed doing a body swap onto an F250 chassis as well as 4BT swaps or 351/ZF5 swaps. The 351/ZF5 swap is straightforward but I don't think it's worth it with this truck. I'd rather buy an actual 3/4 ton for hauling. This truck is very drivable as is, but it's not a great puller.
You realize that genV 5.3 are basically direct injected LS engines right?I saw a 95 1500 for sale with the heavy duty axle swap. If they would have done the 4L80E swap, I would probably own it. Yeah, the stock 5.3 LS, pre Gen 5 motors stock are gutless turds down low, just pathetic.
Sort of yes. Either way they feel like a lot more than 30 hp difference, night and day, maybe the 8 spd too. Pretty sad my 8.5 to 1 Olds 350 with stock 307 5 heads, 204/214 cam, shorty headers, 2.25" dual exhaust and a sbc 350 swirl port tune could out run a 5.3 with the same trans and gearing, idle to 4000 rpm. With a 454 TBI, not even close down low and similar up top.You realize that genV 5.3 are basically direct injected LS engines right?
