my heat doesnt work
illregal82
262
MINNEAPOLIS
my engine swap is done to the drivable point but the heat doesnt work its stuck on defrost and doesnt blow hot at all cant change it and my mechanic has returned to fargo i know one problem is that i need a thermastat there isnt one so the motor runs like 165 170 but all the wires are still pugged in the blowermotor part i need to know where the vacum line starts and where it needs to go and maybe theres more wires need to be hooked plus i have this huge birdsnest of wires i have not yet unplugged my ecm is it safe now and can i remove all those wires what is needed for the heat its a little chilly here in minnesnowta
Chevyman85
594
Bonney Lake, WA
After I did my engine swap I had the same issue. I tore out all the emissions and wiring. For starters the heater door is vacuum controlled. If your car has AC there should be two small vacuum lines with a reservoir tank, w/ out the lines hooked up you can't control the hot/cold switch. You also need to make sure your heater motor is working. I replaced the motor and moved the ground because it kept shorting out. I'm still in the process of fixing my heater. Currently I have only defrost but it
