Welp, sh*t. One thing after another aint it? Rebuilt my qjet, went to put it on, started the car, and it kept stalling out. I had my brother crank it while I operated the choke on the carb, thinking I got that wrong. I noticed the fan wasn't moving and there was a LOT of smoke. Well, that turned out to be the fan belt being shredded. On a whim I looked in the rad, since it was a brisk 15 degrees outside and I thought "wouldn't it be terrible if the coolant froze?", welp, it was terrible. It wasn't frozen solid, it was a thick slush. Like a gas station slushy. It was full of water. I guess I never changed it out to coolant after the radiator hose got knocked off last September, and the car has been broken for three months, so I just forgot. I didn't see any puddles on the ground or any freeze plugs exiting stage left, so I think I lucked out. Tomorrow I'm gonna get two gallons of 50/50 and dump that in, get a new belt (I freed up the water pump, it turns as normal now) and see what happens. The engine would start, idle if you kept on the gas but then shut off immediately. It's getting gas, and the accelorator pump is squirting great. Power piston moves freely. I think it was just the frozen bits stopping the motor from idling.
So, it my engine ok?
