MONTE CARLO 'Mystery Bracket' location needed
chriscris
11
Campbellville, Ontario
For an 87 MCSS, can't find it in any of my pre-disassembly photos.
Any help appreciated
Thanks
Chris
Ribbedroof
4,900
6,991
Wellston, OK
Speedo cable to crossmember?
Ribbedroof
4,900
6,991
Wellston, OK
Other thought is park brake cable, or fuel hardline
Been a while since I had one apart and exposed
CopperNick
3,357
3,018
Canada
Sure it isn't just some orphan bracket that managed to find a way into one of your parts boxes and took up residence??
79 USA 1
1,065
2,039
Cheektowaga, New York
Maybe to run the wire and plastic loom through for the oxygen sensor? May attach under one of the exhaust manifold bolts?
At first I thought it secured the dip stick tube to the manifold but that should be spot welded.
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
I'm thinking fuel or vent line bracket
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Passenger side parking brake cable that loops over the axle? There is a clip bolted to the middle of the crossmember that holds it in place, but I cant remember if it is short or tall, like this one.
