85 Monte Carlo with a 2002 goodwrench 305 crate motor with just over 70K. Ever since the last really big cold snap we got up here my car has been making a really loud noise when it is above 20-ish degrees out and the engine is hot. I thought it was my power steering pump since it was having 'morning sickness' issues, but I replaced it and noise is only getting louder. I can really only hear it at idle up to about 1500 RPM, and it sounds like when you jiggle an old loose doorknob around or the chain lift on a roller coaster ride but much louder. Used the screwdriver to the ear trick and it doesn't seem to be coming from inside the engine. I can also feel it through the wheel and the brake pedal and it is so bad that I can also feel it when the car is idling over the normal vibration of the motor. Whenever it gets chilly outside it quiets down again to more of a metal hitting plastic sound and becomes fairly hard to hear from outside the cabin. Every belt driven accessory has been replaced except the alternator which was fairly new when I bought it and the balancer which is one of my prime suspects now. In terms of performance the engine drives just the same as it ever did which just adds to the mystery. Oil has been changed routinely and motor was clean as a whistle inside when I changed my intake gaskets about 3K miles ago.
