Need a little help with my gauges
bazthespazz
47
4
8
Oregon
I've got a 1984 El Camino with gauges. For some reason they've all stopped working. I replaced the printed circuit board when I first got it about 5 years ago so I doubt that's the problem. The dash lights, turn signals and the clock all work so it doesn't sound like an issue with the ground, just nothing on the gauges. I've tried pushing in on the lower right corner of the dash where the connector is and it made no difference. Checked the fuse and it looks good. I just got it back from the paint shop and everything was working when I dropped it off. Hope somebody has an idea on what to try next.
blk7gxn
1,390
1,886
Is the ground for the lights separate from the gauges? possibility of two grounds?
bazthespazz
47
4
8
Oregon
Looks like just one ground and I'm guessing it's good since all the lights and the clock are still working.
blk7gxn
1,390
1,886
It would have to be a broken board or a fuse then, if the ground is good, there is no way all of the positive leads could be bad at the same time, the only "common" thing they share is the circuit board and a fuse. Good luck ! Hope its simple!
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Do the dash lights work?
57 Handyman
339
389
Comment and a question: A common paint shop practice is to disconnect the battery while painting because of static electricity. In so doing, it may have resulted in a bad ground anywhere due to the surge. When it comes to ground issues, it is not a sure thing to assume the closest or related ground issue is the culprit. I once installed a towing light assembly on my S-10 and that started a problem with my turn signals, emergency flashes, etc. I had to do all kinds of checking and spark chasing before I realized it was the ground at the back of my truck that was causing the problem.
You stated you replaced the printed circuit board 5 years ago. If you installed a new circuit board, then your assumption and belief that it is okay may be correct. However, if you replaced the circuit board with a used one, then that may be your culprit as well because those old circuit boards get so darn fragile as they age. The copper tracings can break under the protective coating and are generally not visible without step by step continuity checks along the path.
Now for my question: How did/or do you remove the metal U-shaped clips which serve as the connectors for the gauge cluster? I am preparing to switch from idiot lights to gauges and am trying to remove the clips without demolishing the printed circuits. As a backup plan, I am considering soldering and running wires in lieu of relying on the printed circuit.
Good luck as you try to locate the problem and let us know what you find.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
57, they just pry out.
OP sounds like he has an ignition power (pink wire or fuse) problem to the cluster; the circuits mentioned as working are all constant 12v.
Except turn, but they're fed off the turn switch....
