Need a Tachometer needle for 85 El Camino
x75
Sep 23, 2018
75
33
I was working on a friend's 1985 SS El Camino because the tach was pegging whenever the engine started. I took the dash apart and noted how many little plastic pieces had cracked/crumbled (we're in Texas). The dash internals look like an injection-molded Revell model car I used to build back in 1960s.
Anyway, I barely touched the tach needle and it broke in half, so I tried to pick up the loose piece and it crumbled into 3 more pieces. As brittle as a toasted hair.
Anybody know of a solution?
Ribbedroof
4,861
6,888
Wellston, OK
I have heard tell of people gluing a toothpick to the hub and painting it to match.
Common problem with no easily found remedy. Somebody is making them (repro speedos and tachs are available), but nobody seems to have just the needles. I have a couple speedos that could use needles. and a tach also.
PBGBodyFan
792
1,220
Wisconsin
Replacement speedo needles can be found on mid 80’s GM vans. They are orange and fit right on, but are a little different style. Better than no needle though. Not sure on tach’s, if they work or if any other vehicles could be donors.
I’ll look at my spare tach pile, they are all busted or unrepairable for various reasons, not sure if I have any 85’ and older style though.
x75
Sep 23, 2018
75
33
thanks for the info. I guess I will have to look at other speedometers to see if there is a similar needle.
It's funny, I asked an instrument vendor on eBay (selling reproduction instruments from Taiwan or somewhere), whether they sold needles only and the reply was "nobody makes just those needles". Obviously somebody does.
Ribbedroof
4,861
6,888
Wellston, OK
I had a similar response from an outfit that rebuilds speedos...they don't have needles for sale, but will rebuild yours for $150...umm....no
