Need advice for parts
Bri guy
845
225
You can buy new bushing an have a shop put them in if you don't have the means or as you know but new arms w/ ball joints - rock auto has them too.
Your right. Just seen rock auto. $68 each for uppers. But no lowers available...
19,992
Buying new is better and cheaper.not to mention your old arms may have stress cracks in them like most do.
No need to clean or paint just unbolt old and pop on new
8,189
17,571
My recommendations- comes complete.
Moog problem solvers
CK620249 RH Upper
CK620250 LH Upper
CK620251 RH Lower
CK620252 LH Lower
Lower ones are 2 WD S-10 parts. Bigger bushing holes on the lowers from what I understand requiring you to open up your mount holes to 1/2" is my understanding. That's why you won't find them in the Cutlass sections. But they're the same arms as G-body. Unless you wanted to change bushings out. But then I'd just buy parts for your existing arms if I were going to do that.
Find them wherever you can get them the cheapest.
Bri guy
845
225
CK620249 RH Upper
CK620250 LH Upper
CK620251 RH Lower
CK620252 LH Lower
Thanks for the part #s. Makes me nervous buying parts and not knowing if they're the right ones. Other people have used these lower arms?
8,189
17,571
Maybe. I don't know. I have NOS GM ones, but if I were going to buy new ones now, I'd get these.
MC96
458
492
CK620249 RH Upper
CK620250 LH Upper
CK620251 RH Lower
CK620252 LH Lower
9/16ths for s10 1/2 for most aftermarket g body stuff. Our frames are so close to 1/2 an old rust drill bit will work just fine.
Bri guy
845
225
Got a small list together. But what's up with the lower arms? Why do they look so different and they say the fit my car?
wskirvin
324
423
Indianapolis, In
I used these exact numbers on my car and no issues what so ever. just buy new bolts for the lowers.
wskirvin
324
423
Indianapolis, In
those lowers dont look correct at all. go with the Moog's that 69hurstolds posted.
