Hello everyone
It's been a while since I have been on this site, and I see it is STILL one of the best!
I need some real expert advice...I am looking to sell my 1979 ProTouring Hurst Olds. I put a LOT of time and money into it and am looking to find the right forum to get the most out of the sale. It is not a daily driver, and I am sure it will take time to find the right buyer; I'm willing to make a deal however I do intend to give it away. I'm not sure if I should start here, Hemmings, or invest in a Mecum's or Barret-Jackson experience (it is that nice).
The suspension, body, interior, and paint were done at Schwartz Performance in Illinois. Everything is top quality and fully documented including an appraisal from No Fear Motor Sports Classic Car Appraisals in Mundelein, IL (appraised value of $260,000 for insurance value only in March 2021). The documentation states " in present condition, this vehicle is capable of competing successfully in very high-level expositions, displays, exhibits, or shows".
The 532 ci BBC was built at LRB Performance Machine in Franklin, NJ and the 4L80E overdrive transmission and custom torque converter at Dynamic Converters Pro-Formance Transmissions.
Engine Bay:
Custom built 532 CI
Dart Big M Sportsman block, 4.600" bore
Mahle pistons
Eagle SHB-6385 H-beam connecting rods
Callies Compstar crankshaft
Custom ground Comp Cams hydraulic roller cam and valve train
Morel hydraulic roller lifters
Elgin SSR-900 rocker arms
FAST EZ EFI throttle body fuel injection
FAST E6 CD ignition module
FAST ECU
Edelbrock Victor Aluminum intake manifold
AFR 3670 300cc aluminum heads
Milodon Road Race Oil pan and high-volume pump
ATI dampener
Billet double roller timing chain
Wilwood master cylinder and proportioning valve
PowerMaster Ultra Torque starter
Custom stainless-steel headers and exhaust
March Billet serpentine system
Griffin high-performance radiator and dual electric fans
Billet Steering Shaft
Power Steering Rack
Fuel Delivery:
Tanks EFI fuel tank and sending unit
Walbro internal fuel pump
Drive Train:
4L80E automatic overdrive transmission
TCI EZ-TCU transmission controller
Custom steel drive shaft
Moser 9-inch differential
Full floater
Currie 9-inch third member
True Trac differential with 3.70:1 ratio
Moser 31 spline axles
Chassis and Suspension:
Powdercoat Schwartz Performance G Machine chassis
Schwartz Performance front suspension components
Schwartz Performance tubular control arms
Flaming River power rack and pinion steering
Schwartz Performance splined front sway bar with aluminum arms
Schwartz Performance splined rear sway bar with aluminum arms
Ride Tech single adjustable coil over shocks
Wilwood 13" front (6 piston) and 12" rear (4 piston) disc brakes
Wheels and Tires:
Forgeline CF3C wheels - 19x9 front, 19x12 rear; Race Gold centers and Gloss Black outers
Michelin Pilot Sport Radial tires - 345/30ZR19 rear and 255/35ZR19 front
Tons of other items
The collection of completed pictures can be found at Washington's 1979 ProTouring Hurst Olds
Other build pictures and detailed documentation are available.
Thanks in advance for your help...
Engine Bay:
Custom built 532 CI
Mahle pistons
FAST ECU
ATI dampener
Power Steering Rack
Fuel Delivery:
Drive Train:
Full floater
Wheels and Tires:
Tons of other items
