Need help identifying cut wiring and unplugged harnesses from previous owner
Capote
26
Newnan, GA
I recently purchased an 84 Cutlass Supreme and a lot of wiring was cut and three wiring harnesses were unplugged on the passenger side next to the a/c & heater box. One large harness was unplugged that runs next the brake booster. Cruise control as removed from this Cutlass, so maybe it has to do with that? I'm trying to unclutter the engine bay, so i just need to know what they all were for and if it's okay to trace them and cut them further or fix them. Thanks in advance:D
I am currently removing the rest of the a/c & heater box. so i'm aware of all corresponding wiring that went to that.
Ribbedroof
4,900
6,991
Wellston, OK
What was the ORIGINAL engine in this car?
Ribbedroof
4,900
6,991
Wellston, OK
What are the colors on the 5 wire plug...hard to tell in photo due to age fade
drogg1
885
213
Here is a link to most of the wiring diagrams for these cars:
http://www.maliburacing.com/wiring.html
That site also has many other good resources although I think you'll find the members here very helpful and friendly.
Ribbedroof
4,900
6,991
Wellston, OK
I believe that is for the cruise control servo
Ribbedroof
4,900
6,991
Wellston, OK
The white/clear plug with brown and red wires LOOKS like the alternator plug
Capote
26
Newnan, GA
That's what I was thinking, being that the cruise control servo is completely missing
Hmm, i can't even pull those wires remotely close to the alternator. And they look like the wires go underneath the distributor somewhere.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I had my wiring chopped up so I replaced the harnesses in the engine compartment with a good harness I found at the wreckers
