Could you please help me I.D. these connections and where they should go...when I took all apart I thought I documented evertyhing well...but apparently not good enough.
The connection coming out of the plastic sleeve in the steering column (bottom of pic)...looks like a low voltage connection.
These two connections
1. black/orange stripe wire with connection coming down from 12V block with red connector on end
2. Purple/white stripe wire with large black connector on end into main harness on fuse panel
