Need help installing viper 5904
jundog89
7
I have mostly every wire connected I just can't figure out how these wires go :evil: , the alarm is going on a 1979 Malibu 2dr .... any help appreciated :D
Remote Start, (H3) 10-pin
PINK. (+) IGNITION 1 INPUT/OUTPUT
RED/WHITE. (87) FLEX RELAY +12V INPUT (30A FUSED)
ORANGE. (+) ACCESSORY OUTPUT.
RED. IGNITION 1 +12V INPUT (30A FUSED)
PINK/WHITE. 30) FLEX RELAY OUTPUT (car side of ign, acc or starter wire)
PINK/BLACK. (87a) FLEX RELAY INPUT (key side of ign, acc or starter wire if needed)
RED/BLACK. ACCESSORY/STARTER RELAY +12V INPUT (30A FUSED)
pontiacgp
blank
Mar 31, 2006
29,156
Kitchener, Ontario
didn't you get this with the installation instructions?
jundog89
Thread starter
Jul 20, 2014
7
Yea I got that done already, I need help on the remote start section.... dont know how to connect it to the ignition harness on the malibu, (like as in which wire goes where)
pontiacgp
blank
Mar 31, 2006
29,156
Kitchener, Ontario
If you're not familiar with the wiring on these cars go back to the store where you bought is an ask for a print out to install it on your specific car.
pontiacgp
blank
Mar 31, 2006
29,156
Kitchener, Ontario
they have programs that have diagrams for the car they are working on. It will also give you a hint on where to the find the wire on the car. If you can't get that I'll see if my friend who owns a stereo shop can get that diagram for your car.
jundog89
Thread starter
Jul 20, 2014
7
The wiring diagram that I have I got it from the12volt . Com not sure if its the same one they have at the stereo shops
pontiacgp
blank
Mar 31, 2006
29,156
Kitchener, Ontario
not many put on a remote start on a carburated car since you have to rig up a way to pump the gas pedal to start the car....and then to shut off the choke
