Need help matching heads to cam
84oldsmo
14
Hi I'm here fora Lil help from who ever can . I have a brand new chevy 350/290 Mr goodwrench I win in a local raffle well I was given a summit 1105 kit I'm wondering what heads would wake this cam and motor up. Not looking to change piston or anything on bottom end I already have a pair of headers and I planned to use qjet carb and edelbrock preformer intake
Cam specs
Basic Operating RPM Range:2,400-6,000
Intake Duration at 050 inch Lift:224
Exhaust Duration at 050 inch Lift:234
Duration at 050 inch Lift:224 int./234 exh.
Advertised Intake Duration:298
Advertised Exhaust Duration:304
Advertised Duration:298 int./304 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.466 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.487 in.
Valve Lift with Factory Rocker Arm Ratio:0.466 int./0.487 exh.
Lobe Separation (degrees):114
Motor specs
Specifications
  • 4-bolt main with 2-piece rear main seal
  • Nodular iron crankshaft
  • 4.000'' bore x 3.480'' stroke
  • Internal balance
  • LT1/LT4 powdered metal connecting rods
  • Cast aluminum pistons (dished)
  • 8.5:1 compression ratio
  • Hydraulic flat tappet cam (.383"/.401" Lift, 194 / 202 Duration @ .050", and 112° lobe separation)
  • Cast iron cylinder heads with 76cc chambers
  • 1.940'' Intake / 1.500'' Exhaust valves
  • 1.250'' diameter valve springs
  • 1.5:1 ratio rocker arms
  • 3/8'' pressed-in rocker studs
  • Any help is appreciated thanks
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
Bar50
1,180
871
Tulsa, OK
Vortec heads
Any 64cc head will go a long way.
383_GrandPrix
678
1,311
Quebec, Canada
He stated that he is looking to get some heads that will match the new cam he has:
"Basic Operating RPM Range:2,400-6,000
Lobe Separation (degrees): 114"
383_GrandPrix
678
1,311
Quebec, Canada
This is a pretty aggressive cam profile. You have 73 degrees of overlap, but you're not getting much lift with factory spec rockers. To get the most out of this cam I would use a higher ratio rocker arm, it will keep the same cam timing and duration but provide more lift. You will however, need to change your pushrod length to achieve proper geometry with the longer rockers. Also make sure that the springs that come on the new heads will handle the lift and ramp rates of your new cam. If your springs are not strong enough you can end up with valve float, and if your lift height gets too high for the spring you end up with coil binde.
  • Informative
