NEED HELP WITH CONTROL ARMS REPLACEMENT
LOCOGOMEZ
117
39
Southern IL
Hello all. I am requesting/inquiring assistance with replacement with my control arms on my 86 cutlass supreme. I know there has probably been a thread on this but asking for help. What have you done or suggest on replacing them? By the way using the same stock springs on it. I have tried looking for a video on this but no luck. Any suggestions? Thank you all in advance for your responses and advice.
GBodyscuffle
349
381
Keysville, VA
Theres really not much to it. Put the car on jackstands, take the weight off of the rear. Remove shocks first, unbolt everything else, change what needs to be changed and bolt the shocks back in. Not really difficult. I do suggest an extra set of hands to aid in wiggling stubborn bushings. They get dry and dont like to come out of the frame mounts easily. Just my 2 cents.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,807
Louisville, KY
In addition, a good working flashlight is also very helpful while under the car ;).
lilbowtie
3,460
3,965
Canton Mi
Not quite sure what you mean by replacing them, you simply remove the bolts on both ends and install your replacement. If you are talking about replacing the bushings you are going to need a press and make up special tools to press them in and out.
LOCOGOMEZ
117
39
Southern IL
Front, back or both?
Sorry I am wanting to do the front upper and lower control arms. I have the replacement arms with the bushings and tie rod ends already installed. Just want to safely do the job with the pressure of the front spring not being to much of a factor.
lilbowtie
3,460
3,965
Canton Mi
The fronts are better known as A arms - good info in thread Pontiacgp posted and as Anubis said in it - leave the shocks in place when undoing the ball joints.
