442 Need help with gas pedal.
Jims442
Jims442
Dec 2, 2019
96
Connecticut
Hey everyone, This maybe a dumb question but here goes. My gas pedal takes a lot of force to accelerate and if you are just tooling around it takes a bit to keep it at a steady speed. Now I believe there's a way to adjust it I think? The car has a mild cam with a small blower and if you hit the pedal hard and fast the tires spin etc etc.. Is this something you do because of the blower and power it makes or could it be the personnel preference who set it up previously? This whole blower thing is new to me, but it's a blast to drive!! Ty Jim.
melloelky
melloelky
2,108
mass
how's the throttle cable look?does it have any sharp bends or is it tight? take a look at it see if it appears to be on the short side.
Reactions: fleming442
lilbowtie
lilbowtie
2,987
Canton Mi
I like to have one on the front side and one on the rear so the load on the bushing is equal ???
Those springs look pretty hefty - that kit comes with different size springs. The way your springs are attached to the throttle your really stretching those springs to get WOT.
Reactions: pontiacgp
Thread starter Similar threads Forum Replies Date
P Need help decoding a 1981 Malibu body tag General Discussion 1
rogus need help with engine id sbc 350 Engine / Swaps / Driveability 4
J MONTE CARLO Wires cut On Torque Converter Lockup. Need help on wiring harness General Discussion 0
P Need help picking rear end!! Transmission / Rear End / Driveline 29
Chuck Cole Need help with my Starter Wires and HEI Plug wire Chevrolet El Camino / GMC Caballero 2
8 CUTLASS 84 supreme 305 swap (need help) Engine / Swaps / Driveability 27
S Need help locating clip Interior 0
rogus Need help identifying something Interior 13
Brettbolte MALIBU Paralyzed n need help New Users 13
Sanchez86Cutlass CUTLASS Need some help with starting issues Electrical / Ignition / Starting 7
M Need Some More Wire Help Updated 4/28 Electrical / Ignition / Starting 16
J Need help plz ! G-Body LS Swap 3
M Need help finding this part Body / Trim / Paint / Glass 5
T MONTE CARLO need help Electrical / Ignition / Starting 0
Dsmooth7 Need help!!! Car was whistling popped the hood and found this.... Fuel / Air / Boost / Emissions 5
L Need help looking for a complete dashboard Interior 3
A Need help bad Engine / Swaps / Driveability 57
C Need quick help with brake line Blazer upgrade Wheels / Tires / Brakes 5
39F No charge need help Electrical / Ignition / Starting 14
Z 1984 el camino, NEED HELP PLEASE! Chevrolet El Camino / GMC Caballero 15
bazthespazz Need a little help with my gauges Chevrolet El Camino / GMC Caballero 58
Myles VERY rough idle, hard start, getting worse need help General Discussion 8
T '87 Monte SS aero throwing 4 codes *** need diagnostic help Chevrolet Monte Carlo / SS / Malibu 10
A Need help 84 cutlass New Users 5
R Need Help!! New Users 2
TURNA Need help IDing manufacturer General Discussion 9
C Cowl to rad support braces-need some help Frame / Chassis / Suspension / Steering 7
Westernave V6 swap to a sbc 350 need help New Users 2
Westernave V6 swap to a SBC 350 need help New Users 10
J rocket 86 cut CUTLASS I need help Oldsmobile Cutlass / 442 / Hurst/Olds 3
GuysMonteSS Need one of these in Canada General Discussion 23
yennchi45 Need Wanted 1
H Need A 1978-83 Buick part Wanted 0
S In desparate need of a passenger front wheel well moulding/trim w/2 tone paint for my 85 ElCo Wanted 3
F Rooftop problem , need recommendations General Discussion 7
Kennyjoe28 NEED! 83-87 regal rear window hard top trim Wanted 9
kornball426 Need a bit of advice/opinions. General Discussion 39
M Need input on carb.. Fuel / Air / Boost / Emissions 11
T Do i need zinc additive? General Discussion 34
Bri guy Need pics of 403 with A.C. Vbelt Cooling / Heating / AC 23
GuysMonteSS Need a measurement please... General Discussion 5
Chuck Cole Need Seat motor plug from fuse box (female end) Electrical / Ignition / Starting 1
harvtown REGAL need vacuum hose diagram 1978 3.8 dueljet Fuel / Air / Boost / Emissions 1
T I need to know what transmission I have in my Oldsmobile Transmission / Rear End / Driveline 1
kygaca In Need of Olds 307 Frame Mounts Wanted 2
Javi702 Do i need this? Restoration 5
Drkuhar Need some 84 cutlass parts Wanted 2
83StreetMachine HELP Need opinions.....head gasket General Discussion 14
J Need Astro shaft Wanted 6
Injectedcutty HELP Need to rebuild my 8.5" boys! Transmission / Rear End / Driveline 47
Similar threads
