Hey all. Just picked up a 87 Monte Carlo LS that has had some work done, but is in dire need of suspension and brake work. Since I'm going to be replacing most of the front suspension and brakes, I'd like to do the lowering at the same time, it looks like about stock height but I'm not sure.
The rear end was replaced with a Ford 9". Since the springs sit on top of this, I have no idea if they're the stock springs, if it would sit higher or lower, etc. I did measure the spring though. With the weight on the car it is 10" tall, with no weight (spring loose in cups) it's about 12 5/8". Can anyone confirm if the stock rear spring is 12 5/8" tall? Not sure where else to start. Car needs to come down about 2" in the rear, maybe 1.5 in the front. No budget for a coil over setup
