I cannot find my old passenger/driver locks. I have new locks. I don't know what it's called but its the piece of metal that attaches to lock and rod inside door. Don't know if pass/drv side are different. Anyone have these?
84 is correct 👌Trying to remember...your car is an 84, right?
Briggs and stratton says the pawls changed for 1985, but as to how, I don't know. Parts book 20627874 shows as a listing for 82-84 G (2 needed), but it also lists 82-83 G-47 which uses a RH and LH, p/n 20188198 and 20188199 respectively. To which, the 1984 B&S lock catalog shows p/n 20188198 and 20188199 for the 84 Cutlass pawls as well. (320986 and 320987 B&S numbers)
85 changed to 20548660 for RH and 20548661 for LH.
Well, mine would be on 1986 regal doors. So.... being as how you don't have something to compare to, can't say how or if they'd work out for you.84 is correct 👌
Why would they make this so complicated???? Could've easily used the same ones standard across the lineupDid you get long or short locks? Highlighted pawls are for the long locks, these will not fit the short locks.
Hahaha! Confusion creates the chaos!Why would they make this so complicated???? Could've easily used the same ones standard across the lineup
