Need Low Tension Hood Hinges For Fiberglass Hood
4
Kaukauna, Wisconsin
I replace the stock hood on my 87 442 with a 2 1/2" fiberglass cowl induction. The hood still uses the front latch and rear hinges but I could not re-install the factory hood lift/spring as it places so much pressure on the hood that is will break the hood. I hate the idea of using a prop rod - I just do not like how is looks at car shows.
Does anyone make a low tension spring for these hood lifts or is there another design out there I could use?
custom442
1,889
4
Houston
Could you build an aluminum brace (1/4"+ thick) across the underside of the hood to strenghthen the hinges/fiberglass?
86MonteLS
30
6
Lima, OH
I'm interested in this too so I know what I'm in for when I install my 4" fiberglass cowl
v8power
563
7
green bay WI
http://www.up22.com/malibu78.htm
i know they make them for the buick and malibu hoods, but i really do not know if all them hood springs are the same, but give them a call once and see if they have them for a cutlass.
jonnyslick
697
2
Crossville, TN
I'd like to see a pic of your car with the hood on.
