Need mech pump to Edelbrock carb fuel line ideas
Michael Bennett
Michael Bennett
Jun 7, 2018
58
8
Looking for ideas on how to run fuel line from my mechanical fuel pump to my Edelbrock carb. I'd like to run a FPR as well. I have an 800 Edelbrock square bore carb and Edelbrock mechanical fuel pump. If anyone has pictures of their set ups with good fuel lines, regulator, and gauge it would be really helpful.
TURNA
TURNA
7,750
Socialist NY
Get one of these screw a gauge into the port on the side and the regulator into the end add a filter and steel braid and your good
8
88ss408
275
baie st anne n.b
Unless he has the victor pump @ 10psi. The performer pump is 5.5 to 6.5 psi
Michael Bennett
Michael Bennett
Jun 7, 2018
58
8
I do have one of the lines like the top picture but the fitting from my carb leaks at the line so I need a new one. I do have the performer pump so I probably don't need the regulator. Just trying to figure out what bits and pieces I need to replace the rubber line with braided and AN fittings.
TURNA
TURNA
7,750
Socialist NY
marz442
marz442
248
Cicero Il
Well you will prob need a right angle out of the pump. about 2 ft of hose a filter and fittings
Get one of these sewing tape measures if you are unsure how much you need or if you want to buy a premade line
Most dollar stores have them.
or just get something on this page
https://www.jegs.com/p/Edelbrock/Edelbrock-Carburetor-Single-Feed-Fuel-Line-Kits/751792/10002/-1
What size right angle fitting? I have a jegs fuel line and it doesn’t match up to the stock factory line!!! The jegs line has a 6an male end please help.
TURNA
TURNA
7,750
Socialist NY
You will probably need a 3/8NPT male to -6 fitting female
But Im not sure since I have no idea what line or pump you have you have
Reactions: fleming442
