Need opinions on motor for the new regal
bracketchev1221
1,411
1,647
I would do the 454. You can build a low compression oval port engine and go in the 12's without much effort.
1,167
2,638
West Virginia
Should I use a 283, or a 454? cannot be a serious question. Let's see some pics of the car and that tunnel ram.
bracketchev1221
1,411
1,647
What kind of cam I was thinking 550-580 range 240 at 50 range?
240 may even be too much if it’s around 9:1 compression. I’ve seen a lot of stock head motors with about 10 degree splits @.050, i was quoted a 229/241 cam for a project I’m doing.
39F
530
602
Pittsburgh PA
The motor has 30 over flat tops I was gonna have it zero decked and small domes have everything balanced goal is to be around 10-1 maybe lil less I want a pump gas motor
39F
530
602
Pittsburgh PA
Was doing some math if I put the 781s with 118cc chambers and a 060 head gasket it takes my compression to 10.48 to 1 ,o think this might be my cheap way out till I save some pennies for bigger crank swap meets are coming up soon I'm just unsure if the cam will work
