Need Opinions!!
Iowa Rockhauler
10
6
Ok since I'm getting seriously beat up trying to find body parts for this car.. What is everybody's opinion on this. Is a 1985 Grand Prix classified as a G-Body. Can I use a aftermarket transmission crossmember classified as fitting a " G-Body" fit on this Grand Prix. I know there's somebody that's already gone thru this but I'm still learning!
buick7332
350
589
N.E. Philadelphia area
I bought a g-force Cross member for my Grand Prix from summit. If you want true duel exhaust its the only way to go.
Iowa Rockhauler
10
6
Finally.. Getting some good news and opinions. I want to run 3 inch with Flowmasters under it but that Grand Prix seems to be a oddball trying to get parts for. Did yours bolt up to the factory holes or did you have to make it work ?
buick7332
350
589
Mine bolted right up. Be sure to get the right tail mount for your transmission.
buick7332
350
589
Did you use the stock mount or get one that's offered with the crossmember. I seen they offered a offset mount. I'm just putting a 350 in it
Off set wouldn't work with My 4 speed. I bought one from summit also but I don't have the part#. When you order your cross member tell them what trans your using and they will tell you the mount you need.
565bbchevy
9,614
12,683
Michigan
Ugly1
1,636
1,369
Lost in the woods of NH
Grand Prix should take most G-body parts. Outer Body panels-no they I believe had their own ( OF THIS I COULD BE WRONG) but frames, drive line, floors, electrical mostly the same.
565bbchevy
9,614
12,683
Michigan
SS_Malibu
1,164
2,035
Mesa, AZ
I too am using the Jegs crossmember in my Malibu with a TH350. If I can't get it to work with my TH400 upgrade, I'll be getting rid of it for the Summit version of the G-force crossmember.
