I installed a new National 8610 pinion seal in the 10 bolt rear end of our '83 El Camino project three days ago. The car is still in pieces, so its just been sitting in the garage. Today, there is a thin coating of gear oil on the bottom of the differential housing. It appears that the new seal is seeping. This was my first attempt at replacing a pinion seal, so I'm guessing I did something wrong. Before I slip the seal over the pinion, I gave it a thin coat of oil so the seal would not stick/snag. Then, I lightly tapped the outer edge of the seal with a brass hammer, alternating sides, until the seal was seated in the rear end snout. Did I miss something? Is there a better way to install the seal? I don't mind doing the job again, I just don't want it to fail again. I appreciate any advice you guys can share. Thanks!
John
John
