It’s my first race project I’ve decided to sell. And I have no real idea on what a car like this would sell for. Any recommendations for a fair price range and thoughts on the car would be great. Everything within two years old, tires have about 15 passes recipes for everything Thanks! Located in south Fl
1980 Malibu
180gph fuel pump,
140 gosh stand-alone no’s pump
Fram external fuel filter
8an fuel lines
An, push to lock lines
Holley non-bypass regulator
Holley non bypass regulator (nitrous)
G- Radiator/fan
External water pump meziere
Rhodes racing 3 gal fuel cell
Line-lock
G body manual brakes kit
Disk,disk proportional valve
Moroso brake adjuster
Auto meter gauges
(Monster tac, volts, oil psi)
B&M bandit ratchet
Kirkey sm seat
kirkey seat brackets
G-force 3in 5 inch harness (latch style)
Xpower16volt D1600 battery
Xpower1514 16 volt charger
Battery box( sealed)
External deral trans cooler,fan
Ignition
Msd Digital 6
Msd distributor
Blaster 2 coil
msd plug wires
Painless performance 8 switch panel
Nitrous express wet kit
Nos wot/window switch
Push to disconnect battery switch
Suspension/body
No rust
2k primer
Summit Mat black paint to protect body
12 point cage
Fiberglass bumper glasstek
Lift off fiberglass hood glasstex
Hoodpins
New door seals
New trunk seals
Ac block off plate
New brake calipers( front / rear )
New brake lines (front)
S10 lowering spindles
Braced and boxed frame(rear)
Rear lowering springs
Brp non adjustable lower(adjustable upper) 4 link
Arp 3 inch studs rear 7/16
Driveshaft loop
Mini tube
Boxed frame
Notched frame
Braided brake lines (rear)
Quick performance 9inch
Carrier 3.73
Moser axles
Arp 3 inch 1/2
2800 lbs
29 10.5 17 plenty of room for bigger tire.
Wheels crager soft 8’s
Engine/trans
Atm innovation 750 e85 carb
2 inch spacer
Hurricane high rise intake
Iron eagle 210cc heads
MLS head gaskets
Arp head studs
Scat h beam rods
kB pistons ( .20 over)
Scat sfi flex plate
Speed master rod bolts
ARP main cap bolts
Scat crank 9000 crank
Speed master roller rockers .60
Speed master pushrods
Howard lifters
Dart rocker retainers
Lunati stud girdle
Prw rocker arm studs
Cam ( no idea)
Hooker super comp long tube headers
Header wrap
Spark plug socks
Felpro gaskets
Trans th350
5000 stall 10 inch
Shift kit
Full manual body
1980 Malibu
180gph fuel pump,
8an fuel lines
G- Radiator/fan
Line-lock
Auto meter gauges
B&M bandit ratchet
Kirkey sm seat
Ignition
Msd Digital 6
Msd distributor
Blaster 2 coil
msd plug wires
Suspension/body
No rust
2k primer
12 point cage
Hoodpins
New door seals
New trunk seals
Ac block off plate
Driveshaft loop
Mini tube
Boxed frame
Notched frame
Carrier 3.73
Moser axles
Arp 3 inch 1/2
2800 lbs
Engine/trans
2 inch spacer
MLS head gaskets
Arp head studs
Scat h beam rods
Scat sfi flex plate
ARP main cap bolts
Howard lifters
Lunati stud girdle
Cam ( no idea)
Header wrap
Spark plug socks
Felpro gaskets
Trans th350
5000 stall 10 inch
Shift kit
Full manual body
