need some pics on how everyone mounted there trans koolers
B
blu402mally
30
8
can anyone post of some pic'S ON HOW SOME OF YOU MOUNTED STAND ALONE TRANS KOOLERS....HAVE Perma Kool trans koolerfor an 80 malibu...thanks
Local Hero
Local Hero
536
Northcoast, Cleveland, Ohio
In the "function over form" department, I just used the through-the-radiator plastic zip ties and mounted it directly to it. Apologies for the poor picture quality. I did a much nicer installation on my Cougar because I cared more. But here's the wagon.
wonderboy24
wonderboy24
1,290
Davenport, Iowa
been thinking of putting one in my cutlass. i know dumb question. your lines to the radiator. you remove them from the radiator and cap the radiator. and run them to the cooler.
fleming442
fleming442
8,929
I pulled a tank off a newer, plastic and aluminum radiator, and the trans cooler was laughable. I deemed it unnecessary at that point.
Reactions: kiko and Rktpwrd
lilbowtie
lilbowtie
2,843
Canton Mi
You can run to the radiator cooler first and then threw the auxiliary cooler to the trans or if you a big enough cooler use just that. 175 deg and under your doing good.
Reactions: Injectedcutty
