HELP Need to rebuild my 8.5" boys!
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
Alright guys, finally at the stage where I'm contemplating on how to rebuild the rearend in the Cutlass. I have one of the desired 8.5" from a 442 that currently has stock axles, a Richmond powertrax posi and the stock 3:73's. The posi makes some odd noises at low speeds due to a bent axle issue that occured when I acquired the 8.5
I'm not interested in getting a 9" since I know with the proper parts my 8.5" will be strong enough for what I throw at it.
Here is a list of parts that it needs. Any advice on ring and pinion brand is appreciated. I don't mind spending a few hundred on quality gears if the reputation backs it up. Also, forged pinion yokes....I already have a conversion U joint in the driveshaft, just need a new 1350 joint and associated pinion yoke. Quick performance has their brand forged yoke for only $70....seems like a smoking deal if it's strong.
Thanks in advance guys, and I'll update this as needed once parts are acquired and/or installed.
81cutlass
4,645
13,561
Western MN
Quick perf has their store brand 30 spline posi on ebay for $280. I asked who makes it and it literally is a Yukon. My first one even came in a Yukon box.
Quick will sell a posi with install kit and gears for $500.
I have the moser axles in my 8.5 and they are good. They come with holes press in or screw in studs. I bought metric studs and they are drilled for press in or screw in 7/16". I hand drilled the press in holes for M12 studs and used Morroso 2.5" studs. I have not been overly happy with the quality of Dorman studs.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,808
Louisville, KY
This is the answer I was needing. I saw there posi and gear sets but didn't have any branding on them. I've heard bad things about the Yukon posi units, but could be operator error as well. Streetbu has a truetrac and said it's super quiet and nice.
Are you running the Yukon posi in your 2+2?
Rktpwrd
Builder of Cool Shjt
4,166
23,915
Calgary, Alberta, Canada
X2 on the Moser axels. Money well spent IMO.
As for the diff cover, I’d suggest an aluminum one with the bearing cap preload bolts, as for which one, it’s up to you who’s name you want on the outside. I’m pretty sure one manufacturer makes them for everyone, with just different names on them. The one on my 12 bolt is from T/A performance.
They also look real nice when installed with an ARP polished bolt/stud kit.
melloelky
4,157
9,548
mass
i don't have any experience with the 8.5's but all my dealings with quick performance have been very good.
20,391
Haha, what I mean is should I leave the 8.2 cover on it, or upgrade to one with a fill/drain holes and cap girdle??
I knew what you meant but I wouldn't be me if I didn't jump on that... :popcorn:
I like that trutrac, so much better than the posi carrier
melloelky
4,157
9,548
mass
he made this list on the back of an envelope-he got the corona check,flipped the envelope over and made this list before anyone knew what happened...
Reactions: 7 users
