Steve, 08Malibu is right, these doors are quite heavy and unwieldy. I suggest doing it on smooth, level surface that you can easily maneuver a floor jack on. Also, have a helper! Take a look at the tool below.
When I took the door off of the
H/O I was parting out, it slipped off of the jack. The door dropped and slid right under the car. Luckily it was complete garbage, or it would’ve been a bad deal. I wound up dragging it right out to the truck by the wire harness and it was a b*tch to get it up into the bed.
Remove/install door by yourself;fits floor jack with removable saddle
www.eastwood.com
It helps a LOT to keep things steady as you reattach the door.
