New 350
Lue
868
46
Los Angeles, california
Hi Everyone,
I recently got a 78 Malibu Classis with the original 305/th350. I'm currently driving her on a daily baises, and she is in need of a new set up. I been looking around and i found a performance shop that sells engines. I'm looking to get 350-375 hp. I want to run a set up that is reliable and confortable to drive on the road and street. I came to the conclusion that i want a four speed transmission to run with my new engine. Here is an overview of what the new engine set up looks like:
CHEVY 350 — 325 - 327 - 330 HP
4 BOLT MAIN
MIDNIGHT BLACK CRATE ENGINE
BEST STREET DEAL
$2095 basic price for 4 bolt main
(Pricing ranges from $1995 for 2 bolt main to $2295 for 4-bolt main, depending upon upgrades.)
1955 up to 1986
This Power2® Engine combination would be great in your muscle car, street rod, truck, 4x4 or Jeep. NO core required (except in AZ). This engine is a 4-bolt seasoned heavy duty Chevy Small Block. Engine will run on unleaded fuel. Comes completely assembled.
SEAL POWER HYPEREUTECTIC FLAT TOP PISTONS
Steel forged rods, Nodular crank.
Chrome valve covers, timing chain cover, 5 qt oil pan,
timing flag, NEW polished intake manifold,
Professional 8" harmonic balancer, flex plate.
NOTE: YOU CAN ALSO ORDER THIS ENGINE WITH A 5 QT CHROME OIL PAN. JUST CALL US AND WE WILL BUILD A CUSTOM ENGINE PACKAGE FOR YOU.
ALL OUR ENGINES 327- 350- 383- 396- 427- 454 ARE CUSTOM HAND BUILT.
This Power 2 Engine is totally REBUILT in our Machine Shop by professionals from start to finish.This Power 2 Engine Performance Combination was developed from our over 35 YEARS of experience on MUSCLECARS, STREET STRIPS, CUSTOM TRUCKS, 4x4s, and JEEPS. Phoenix Engine Rebuilders has built over 130,000 quality engines to date.
Warranty and Shipping Info:
This engine has a one year written warranty. Buyer pays actual shipping costs if unable to pick up engine from our shop in Phoenix AZ. Some state freight restrictions apply. Payment due in full prior to shipping. We accept Visa/Mastercard, money orders, cashier's checks and direct deposit. (GET A DISCOUNT WITH A DIRECT DEPOSIT!) Business or personal checks must clear prior to shipping. Arizona residents must add 8.1% sales tax.
NO CORE REQUIRED except in Arizona.
What comes with your Power 2® engine?
Here's a listing of the parts and machine labor for your Power 2® engine from Phoenix Engine Rebuilders.
POWER 2® ENGINE PARTS include:
Power 2 cam kit
Power 2 hydraulic lifters
Power 2 spring set, heavy duty (900, series spring sets)
Polished Intake Included
Heavy duty steel intake valves
Heavy duty steel exhaust valves
Premium positive valve seals, polyacrylate
Heavy duty roller timing chain
Controlled internal oil system (a PER exclusive!)
Heavy duty, high volume Melling oil pump
Heavy duty steel collar oil shaft
Heavy duty oil pickup screen
High quality American Seal Power/SL hypereutectic pistons
PER® High Performance plasma molly rings
Brass freeze plug kit
High quality rear main seal double lip polyacrylate
PermaTorque heavy duty gaskets and gasket set
Main bearings, Tri metal, high quality
Rod bearings, Tri metal, high quality
New rod nuts installed
Cam bearings, high quality 360 Set
POWER 2® ENGINE MACHINE LABOR includes:
PER 4-angle® valve job
Mill-matching surfaced heads
Heavy duty thick wall valve guides
Valve guides custom cut for posi-seals
Jet vat block and magnifluxing
Remove and replace all freeze plugs
Remove and replace gallery plugs
Remove and replace cam bearings
Custom centerline boring of block (true 90 degree V8 centerline)
Power hone to fit pistons and rings
Custom crank Micro polish radius oil holes
Rods pressed off, then heat fitted
Rods checked for alignment
Street balancing
* Note: When we custom build your engine, you can choose from 15 different colors or you can supply the paint to have your engine painted the same color as your car's finish!
Please note photos may vary from actual product as all our engines are custom built.
You mean like an MSD or Accel box? I would say no. Your original HEI ignition should do the job just fine.
Yeah, the HEI will be fine so long as it is in good condition. Check the advance mechanism to be sure the bushings are good and also check the distributor shaft for excesive play. Install a new distributor gear with assembly lube when you put it in so that they break in and set the proper wear pattern together.
