well i am currently emailing the engine builder back and forth.
Dosnt sound too promising for me however.
Thsi is an email from him when i was shopping and questioning the engine,
With the right optimum carb and intake 325 hp and very close to 400 + tourque . Keep in mind this is real world not burger king HP . Also it is a premium street thumper worry free pump gas build . It is designed to provide power and tourque in street and mild bracket applications . It is not a race motor . Your intake is a compromize , but a nessesity for egr . The carb I think will work but I think will limit hp and rpm to around 5500 to 6000 . Engine it self will have no issues going 6 to 65 with a Holley style 750 .and worth 25 hp . The carb can be changed any time . Not sure if it helps but I would give the same deal if you wanted to put it on a credit card.
Now i ended up buying performer rpm intake and carb was rebuilt by carbrebuilders after i bought the engine, i sent build sheets and specs.
This is newer emails.............after i sent pics and findings
yep . You do not have a valve train to substane 6000 rpm. the valves start to float and everything crashes .
You ccan go to a chrome molly heat treated push rod and roller tip rockers .
Still the valve spring is your limit 5000 to 5200 rpm area . That,s what the engine is designed for .
The rockers and push rods are just under $400.00
I said...........
Well this is for sure shitty, in our first emails about an engine for my car I did tell you my WOT shift points, rear end ratio and what not. You told me this engine with a 750 carb would have no issues 6000 to 6500 shifts. Now you are saying after its all in and im having problems it is not built to really go past 5000 rpm? I would not have installed this engine knowing that as I spent a fair bit on having a 200r4 over hauled and fully built to shift hard and high when stepping into it. It never goes to the track and spends 95% of its time at 1800 to 2200 rpm. So I guess this engine wasn't what I needed after all.
i recieved back.......
Dave the engine does not make power there , why take it that high ?????
You had buget and the diference between a 5500 rpm engine going to 6 ocasionly and a designated 6500 rpm engine is about $2000.00 diference .
Do not make me feel I miss led you .
he said 1 year or 20,000 km warrenty,
this is engine info.....
fully rebuilt 355 cu SB Chevy engine . All new and fresh . Although designed for street use it received all the same prep work as our all out race engines . The block is a early 2 bolt , bored and honed with a deck plate , alighnhone mains , decked square .
Fully balanced rotating assembly , Flat top pistons , Molly rings , HI Pres oil pump , pick up , steel collor drive , double roller chain .
Brand new pan and timing cover . Comp Cams CS 279 H-107 Thumper series cam shaft , 441 casting 2.02/ 1.60 valve cyl. heads . Has all new bronze guides , Comp valve springs , HT locks and stainless roller tip rockers .
It is assembled with all new head bolts and hardware and premium graphite gaskets.
