87 Grand National
I converted the front calipers to 2000 S10 blazer, changed all the brake lines from Inline tube also bought inline tube rear caliper conversion kit https://www.inlinetube.com/products/dbk1012gx
new brake booster, PV4 proportion valve with the bleeder tool (to not allow the shutter valve to close) new master cylinder from O'reilly - I bench bleed before the install.
rear is getting little no pressure. I gravity bleed > I had a friend help pump while I release pressure from the bleeder valve and I'm getting flow with little to no bubble in the clear lines but not enough to move the piston to clamp the rotors..
I'll notice the piston slightly moves when trying to build pressure and when I open the valve it sinks back in..
