New build for Michelle
David.C
David.C
130
199
#61
I guess I'm one of the twisted F%^$S that actually likes wiring. :mrgreen: Wherr ya at?
I'm in central Tx. (Killeen to be exact). My guess is you are nowhere close to here? If you are, you're more than welcome to come over for an adult beverage and a wiring party.
David.C
David.C
130
199
#64
The car is back home ready for me to start some assembly before final paint. However, I had to leave town for work (2x weeks) literally the day after I got it. FYI, that sucks. It's like having a new bike under the Christmas tree, but you can't ride it until January :(.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F9TxqZvg.jpg&hash=2cb4e3a0b2b7d221d6147c31310c0067
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FThsUgec.jpg&hash=1ce285fd64ca5ffafdf000992a8f83dd
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F9UgeTkN.jpg&hash=09202a5371cd43271f7e433042ea6756
David.C
David.C
130
199
#65
Sometimes you have to go backwards to move forward... Rear end & 3rd member housing completely blown apart for powder coat; Along with the lower trailing arms, core support, and front spindles. Time to finish POR15 on the frame rails and undercoating the the rest of the car.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FKV2QJtf.jpg&hash=6d0ffaaf251ca0cceeb3bc8776c23189
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F5zwN8tt.jpg&hash=3e28d404adbc8bc6ac85aaaa0b628f3a
David.C
David.C
130
199
#66
Finally getting some stuff done, and the newly PC'd parts.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FiIkjJC5.jpg&hash=3cdcbc42f089b75533b25860e9e6a38e
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F0dchNsa.jpg&hash=9274a8511e56ff45fcade7a725e591eb
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FyFGFe5n.jpg&hash=14a8c803fde8d018f24b1c0e686597fb
David.C
David.C
130
199
#67
Ended up having to reuse the stock column mount at the fire wall. Drilled out the welded nuts with a 1/4" inch bit. Add $8.40 worth of stainless hardware from Lowe's, and... wallah we have a much cleaner firewall. Way better than the stock bolts coming from inside out (and those f**kers are sharp too, lol)
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FCIlbJK4.jpg&hash=220ce1e123b72b1416c80ea346fa4cae
David.C
David.C
130
199
#68
Got a little more done, steering column in, and everything fitted up. Made a gasket for the AC box (kind of a PITA & time consuming), will start to fit up the vintage air unit tomorrow.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F5T9naO2.jpg&hash=50100195dcd18bdd90b6e03c25c7b8df
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FcW3f3iD.jpg&hash=144b9f18aa0384e7151b790b507bae88
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F9s6tRfI.jpg%3F1&hash=fe62a7f0036058858a676511bb7b5451
David.C
David.C
130
199
#69
I promised a write up for the Vintage Air unit I purchased from ArizonaGN. To be clear, I am super happy with the purchase thus far. They have managed to cobble a Vintage Air Magnum unit with some custom pieces for G Body cars. It has literally saved me hours of time and $ trying to figure it out myself. That said it’s not perfect, nor is it a quick easy bolt on.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FFYGonj3.jpg&hash=3d57e71bb28973e990239fb0b0abb4d6
The firewall plate comes tig welded and powder coated satin black. It also doubles as the mounting point for the unit (3x button head bolts). It has a very nice 4 port AN connection fitting for your heat and air connections. Lastly it comes assembled with the unit attached to the plate. (It does not come with a gasket, I made mine.)
NOTE: Space is limited behind the plate, so I had to take apart the assembly to determine how and where I wanted to mount my ignition box and coil. It was also complicated by the proximity of the AN connections on the back side (IE it’s hard to get a wrench in there). Which means reassembly is even more difficult.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2Flx7TaIB.jpg&hash=9980d59f396477086eb0253616491a7b
Once assembled the entire unit slides in from the front of the car. You must remove the dash from the car for installation. You may have to fold in the upper lip of the AC opening for clearance (pic provided by Arizona GN when ordered). I did not have to clearance near as much and the unit went in easily.
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FR29SMew.jpg&hash=3e3ce60ad45f72b54fa11fbebe68d177
Once the unit is installed there are some clearance issues. It sits very tight to the kick panel (pictured) and there is a clearance issue with the plastic factory duct (also pictured).
proxy.php?image=https%3A%2F%2Fi.imgur.com%2F6040l38.jpg&hash=346fa739aca20a9f88f87e29a0f6a2ef
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FP8TuI9h.jpg&hash=428a5051118f3827f2658733ee6be892
proxy.php?image=https%3A%2F%2Fi.imgur.com%2FfmnDPfJ.jpg&hash=83517140d81759f06512613419e59a11
This is as far as I will go with the installation for now. I will resume when I start the interior work and wiring.
TURNA
TURNA
7,215
9,611
Socialist NY
#70
Looks like a nice unit, but for the money it costs it should fit a little better!!!
