It has a been awhile since I posted last. I have been very busy with work and working on my 85 el camino as time permits.
I am at what should be the end of a relatively long project for me working as time permitted. My 85 EC had a 305 with almost 100k miles. It still had the stock heads and manifolds with the CCC carb. I did a compression test on the old motor and I had about 180 pounds of pressure for each cylinder, I decided to improve the camino by removing the smog stuff and replacing stock with the following items:
1.) new Comp Cams 388-12-4 camshaft with conventional hydraulic lifters about 440 lift;
2.) rebuilt corvette 113 aluminum heads with d port exhaust (similar to the fast burn heads) and factory guideplates;
3.) LT1 exhaust manifolds as they handle the angle plug heads without problems;
4.) HEI distributor with mech and vacuum advance; and
5.) Summit roller rockers with 1.5:1 ratio;
6.) edelbrock aluminum performer intake; and
7.) Mountainman Qjet rebuilt.
I also added the serpentine belt system.
I cannot get this motor to run. Just came back inside after pulling number one plug and rolling motor to TDC. Distributor was a little bit more advanced previously. Reset timing static to a couple degrees before TDC. Still the motor does not run. The motor has backfired a couple of times (most recently through carb but with previous timing also through exhaust). I have checked the firing order repeatedly. I have checked the voltage at the battery (13.2V). I have checked the sbc distributor rotation as clockwise.
My current plans to fix include:
1.) Cap off fuel line from tank and use ether/starting fluid to try and start vehicle in an effort to isolate carb from the fix (if EC runs on ether sprayed into carb but not on 93 octane from carb then we have a carb problem).
2.) Pull all the plugs and do a compression test (if they all have good compression and they are all within 5% of each other then we can eliminate valve lash and camshaft installation.
By the way the motor has oil pressure when cranking and was lubed by cranking oil pump with adapter prior to installing distributor (and lifters were soaked in oil for days prior to assembly and all cam lobes were were lubed).
Anybody have nay suggestions on where to go next with figuring this out?
I look forwarding to hearing from the board's collective wisdom.
