Broke in correctly. Have right under 20 hours of run time so I just did first oil change, re torqued heads, changed air filters. I filtered the old oil and this is what I found. Would you consider this ok???
Never had this type of compressor at home. Did many oil changes at work but never checked oil for debris. Always had analysis done with high end comps for plants i worked at.
