EL CAMINO New group member
Art Carabio
16
15
Hello,
Thanks for the add. I'm also a member of some other groups like 3rd Gen, B Body (Caprice, Impala SS) and a few others. My '80 El Camino has been customized with a Crystallite Engineering IROC body kit (minus the Camaro nose), an '88 Camaro IROC interior including the dash, console, door panels, seats, and steering column. An '88 Camaro 350 TPI engine with a 700R4 and posi has also been added. I'm currently retro-fitting the original gas tank which the sender unit was modified with a return line. The fuel filter and fuel pump are on the frame rail. My plans are to replace the gas tank with a '96 B Body Roadmaster EFI gas tank. I heard it will fit but am noticing the filler pipe needs to be modded. I'll be asking some questions in this group regarding the best way to either use my old filler neck or modify the Roadmaster filler. Anyway, more to follow. Thanks again
Reactions: 4 users
pagrunt
9,128
15,257
Elderton, Pa
Welcome & thanks for reminding of the late '80's/early '90s with your Elky. Have you ever thought of just going with a tank & pump for a 4.3 instead since it'll be a direct fit?
Art Carabio
16
15
Yes, I've seen that and I'm confident that would be a direct fit with a high pressure pump. My car has always been on a budget and thankfully I'm able to do all the work myself. The gas tank is no different. I picked up the wagon tank with the sender unit for $200 near me so I figured I might have to do some mod to it. I just posted a new thread in the El Camino section. Thanks for the welcome and prompt reply and suggestion.
Art Carabio
16
15
Yes, this car was definitely an early 90s build. It's just stuck with me since then. I crunched the IROC nose and went with the stock later El Camino quad light header/grille. I have thought of pulling off the body kit and go back to stock but then I'd need to fill all the holes in the sheetmetal, replace the tailgate, rear bumper, etc. I figured I'd just repaint it like it is. The clearcoat is starting to breakdown due to the inferior nature of the paint brand I bought (Wanda) from the paint supply store. They said they'd make me a deal when I'm ready to repaint. Wondering what color to paint it with the tan interior.
1,167
2,638
West Virginia
Nah man! Leave it alone. It looks real good.
Longroof79
Rocket Powered Basset Hound
G-Body of the Month
Oct 14, 2008
12,156
9,762
Gainesville, Fl
Welcome aboard, Art.
That's a sweet lookin' El Camino.
Crystalite Engineering had some cool goodies back in the day. :cool:(y)
