so I'm swapping a 72 olds 350 in to a 1983 cutlass. I'm deleting the cruise control, so I need to run a speedo cable from a car that came from the factory without cruise. the problem is that my stock speedo cable looks like it is too small to fit into the square hole on the trans side of things. the car came with a chevy 305/th200 combo and I'm using a th350 that came from an oldsmobile car. so I need to figure out what part to look for. it needs to be the proper length for a g body, but with a larger square to fit the transmission end of things.
also I am using an edelbrock performer carb/intake setup. how do I hook up the vacuum advance timing hose from the carb to the manifold?
the motor was previously converted from points to HEI and I have two wires (red n black), the car had a plug to the distributor with three wires connecting the old motor. without the battery in the car, is there any way to tell which of these I need to be using, and what should I do with the left over (third) wire. what is it for?
thanks in advance for your help.
