Hello fellow g body enthusiasts I have a 83 monte I'm doin a cam swap I was wondering do I need to degree it
In a 305 or something bigger? For me I always degree my cams but I have all of the tools to make it quick and easy and I have done it many times but the reality is that most mild street cams for SBC already come with 4 degrees advance already ground in so you could set it at straight up with no degreeing and you should be fine.Hello fellow g body enthusiasts I have a 83 monte I'm doin a cam swap I was wondering do I need to degree it
I see ok thank you for the information I'm using part number 2102 cam with lifters edelbrock and the timing chain as well ima give it a go I have it already some what apart was supposed to be done yesterday but I was iffy about the degree partIn a 305 or something bigger? For me I always degree my cams but I have all of the tools to make it quick and easy and I have done it many times but the reality is that most mild street cams for SBC already come with 4 degrees advance already ground in so you could set it at straight up with no degreeing and you should be fine.
