Starting in 1979 Buick only made 6 cylinder motors. You got to go to the 70's for a 350. The older ones will be redWhere do I pull a Buick 350 from? Which 80s model has them and which color should I look for
I never heard of a Buick 307Only 80s model using a buick 350 was probably the 1980 riviera, Electra, lesabre, or estate wagon.
In 1981 they went to the 307
There isn't one.I never heard of a Buick 307
the highest compression buick 350 was only 10.25:1 on paper, in practice it was 9.7:1 at best.Stay away from the high compression motors. That would be 1968- 70. It is very hard to lower compression because Buick did it with the pistons.
I had the 1968 LeSabre with a 350. The best gas available would not stop the detonation. I replaced it with a 1974 short block but retained the '68 heads and the four barrel intake. That was the answer. I could run cat piss and it ran great. As for the crummy oil pressure the TA oil pump kit boosted mine way up there. It came with new gears, shims, and several pressure bypass springs. All that said I really loved that 350 motor in that '68 land yacht.the highest compression buick 350 was only 10.25:1 on paper, in practice it was 9.7:1 at best.
